24.02.2006, 17:01 Uhr
Olli
So,
meine Seagate ist da, und mit WDC 4.1 oder hoeher gibts ja nun auch die Moeglichkeit diverseste MFM Platte an seinen P8000 zu haengen. Da ich zum rumspielen keine der "orginal" "Robotron" Platten die ich habe ueberspielen wollte halt eine "neue" von ebay.... und siehe da es funktioniert sogar
Quellcode: | : fd(0,9)sa.format
>>> Format Hard-Disk 4.1 <<< Firmwareversion 'WDC_4.2' Number of Drives: 1 (Drive 0) Error on RESET Cyl 0 Hd 0 Sc 1 of Drive 0 not readable
List of Drive-Parameters: |No.| Name | cyls; hds; secs; prae; ramp; ----------------------------------------------- | 1 |NEC D5126 | 615; 4; 18; 128; 12; | 2 |NEC D5146 | 615; 8; 18; 128; 12; | 3 |ROBOTRON VS | 820; 6; 18; 820; 1; | 4 |ROB K5504.50| 1024; 5; 18; 1024; 1; ----------------------------------------------- Which Typ ? (No./n/q) n PAR --- Drivetype: ' ' PAR --- Cylinders: 100 Heads: 2 Sectors: 18 Praecomp: 100 Ramp: 1 Parameter for Drive ok ? (y/l/p/q)p Parameters: b(Drivetype(ASCII)) c(Number of Cylinders) h(Number of Heads) s(Number of Sectors) p(Begin Cylinder of Praecompensation) r(Distance of Cylinders for Ramp Mode) e (End of Input) q (Jump to the End of 'sa.format') Parameter: (b/c/h/s/p/r)value,e,q bST251-1 Parameter: (b/c/h/s/p/r)value,e,q c820 Parameter: (b/c/h/s/p/r)value,e,q s17 Parameter: (b/c/h/s/p/r)value,e,q h6 Parameter: (b/c/h/s/p/r)value,e,q p820 Parameter: (b/c/h/s/p/r)value,e,q r1 Parameter: (b/c/h/s/p/r)value,e,q e PAR --- Drivetype: 'ST251-1 ' PAR --- Cylinders: 820 Heads: 6 Sectors: 17 Praecomp: 820 Ramp: 1 Parameter for Drive ok ? (y/l/p/q)y Read Error Cylinder 0, Head 0 Format Cylinder 0, Head 0 No Entries in Bad Track Table (BTT) of Drive 0
Manual Input of bad Track of Drive 0 (y/n/q) ? n
Format Begin: Cylinder (a/Start-Cylinder) a Ready for Format Drive 0 from Cyl 0 Hd 0 to Cyl 819 Hd 5 ? (y/n/q) y New Entry in BTT: Cyl 753 Hd 0 New Entry in BTT: Cyl 760 Hd 0 New Entry in BTT: Cyl 761 Hd 0 New Entry in BTT: Cyl 762 Hd 0 New Entry in BTT: Cyl 763 Hd 0 New Entry in BTT: Cyl 764 Hd 0 New Entry in BTT: Cyl 765 Hd 0 New Entry in BTT: Cyl 766 Hd 0 New Entry in BTT: Cyl 767 Hd 0 New Entry in BTT: Cyl 768 Hd 0 New Entry in BTT: Cyl 769 Hd 0 New Entry in BTT: Cyl 770 Hd 0 New Entry in BTT: Cyl 771 Hd 0 New Entry in BTT: Cyl 772 Hd 0 New Entry in BTT: Cyl 773 Hd 0 New Entry in BTT: Cyl 774 Hd 0 New Entry in BTT: Cyl 775 Hd 0 New Entry in BTT: Cyl 776 Hd 0 Format Cyl 819 Hd 5 PAR --- Drivetype: 'ST251-1 ' PAR --- Cylinders: 820 Heads: 6 Sectors: 17 Praecomp: 820 Ramp: 1
18 Entries in Bad Track Table of Drive 0: Cyl 753 Hd 0 Cyl 769 Hd 0 Cyl 760 Hd 0 Cyl 770 Hd 0 Cyl 761 Hd 0 Cyl 771 Hd 0 Cyl 762 Hd 0 Cyl 772 Hd 0 Cyl 763 Hd 0 Cyl 773 Hd 0 Cyl 764 Hd 0 Cyl 774 Hd 0 Cyl 765 Hd 0 Cyl 775 Hd 0 Cyl 766 Hd 0 Cyl 776 Hd 0 Cyl 767 Hd 0 Cyl 768 Hd 0 Rewrite PAR&BTT from WDC-RAM to HD-Drive 0 ? (y/n)y
End of 'sa.format' (y/n) ? y Exit called
Ich glaub ich schreib zu meinem P8000 blog (liesst das eigentlich irgendwer? hehe) noch ein deutschsprachiges HOWTO fuer so Sachen wie "fremde" Platten an dem P8000, serielle Verbindung mit einem PC usw usw.... -- P8000 adventures: http://pofo.de/blog/?/categories/1-P8000 |
