04.06.2013, 20:04 Uhr
Take a look here: http://www.tiffe.de/Robotron/PDP-VAX/E60/I17.jpg
I have the docs for a similar board:
http://www.tiffe.de/Robotron/PDP-VAX/E60/I17-1.jpg http://www.tiffe.de/Robotron/PDP-VAX/E60/I17-2.jpg http://www.tiffe.de/Robotron/PDP-VAX/E60/I17-3.jpg
But this isn't the same, it has a single 50 Pin connector where my board here has two connected in parallel 40 pin connectors (there are more differences). I have the docs for the CM5300.01 too and the drive also, but since all the signals are only going to bipolar devices like 74245 or 74374 and the board has a a K1804 (Am2901) bit slice CPU the signals could be everything...
There are long and short names for most of the boards in a E60, The I17 is the short one, another is MC2707. I have the docs and the schematics for almost all of the other boards. Do you see my avatar? Thats the M2 CPU of the E60... Here are docs for the other boards with this short names as you can see:
http://www.tis.kz/forum/topic.php?forum=28&topic=3
I've looked at www.tis.kz this moment, I know about that page, I think he has newer controllers for the CM5300.01 with an K580IK80 on them, half size boards only. Another one on this page is build out of I3000 Chips (K589..), this one is even better, it has two 64 pin connectors... nothing is similar to mine.
Andrey_AK and Kaldych are names that are known to me, I think Oleg ("Form", from pdp11.ru) from Novosibirsk has already contacted them about my problem...
It would be really nice if you could ask there for news in this regard for me, we need to get the tape up and running to write a boot tape for the Robotron K1630 in Merseburg. This is another PDP11 clone, but a really weird one with some special bus chips that needs initialization before the hardware can be accessed. The machine can only read 800BPI Tapes and my DEC TZ07 can only write 1600 and 6250BPI...
| Zitat: | hm... im have new CM5300 device with all manuals and scheme but don't have any tape controlles. I want to find electronica 60 computer and this tape controller. But i don't know what is "I17" ? Tape controllers in USSR called "НМЛ" - NML (nakopitel na magnitnoi lente) "drive on magnetic tape"
Yes, I know, I can read some Russian, but can't write it anymore..
Ahh, an 8 Bit bitslice with 60 pins connector...
You should better have written "one of the possible electronica 60 NML Boards.."
Regards,
Holm -- float R,y=1.5,x,r,A,P,B;int u,h=80,n=80,s;main(c,v)int c;char **v; {s=(c>1?(h=atoi(v[1])):h)*h/2;for(R=6./h;s%h||(y-=R,x=-2),s;4<(P=B*B)+ (r=A*A)|++u==n&&putchar(*(((--s%h)?(u<n?--u%6:6):7)+"World! \n"))&& (A=B=P=u=r=0,x+=R/2))A=B*2*A+y,B=P+x-r;} Dieser Beitrag wurde am 04.06.2013 um 20:46 Uhr von Rüdiger editiert. |
