28.02.2013, 12:37 Uhr
lux-O-mat
Hello Ermanno,
| Zitat: | Astharot schrieb Hello Freinds, news in my fix kc85.. i discovered that if i leave video board named 4484.898.02903l01 the led green system is light on. |
The video board generates the system clock. If it is disconnected, the CPU wont run and the LED will stay turned on. If the CPU is running, the LED will turn off a short time after power-on.(Someone correct me, if I'm wrong)
| Zitat: | | Sure i have pcb with wires cut... is possible sayed me where found the pcb pics of boards in this mode i rebuild the wires in correct mode. |
Some lines on the pcb were cut from the manufacturer, also some wires are original. Not sure about your board.
Greetings, Jan. |
