            23.10.2010, 18:36 Uhr
          Im originalen Brenn-Programm von robotron wird CRC-CCITT / CRC-16  (x16 + x12 + x5 + 1) genutzt. Der Startwert ist 0xFFFF.
 | Quellcode: |  ; CRC berechnen
  crc:        ld    hl, 0FFFFh crc1:        ld    a, (de)         xor    h         ld    h, a         rrca         rrca         rrca         rrca         and    0Fh         xor    h         ld    h, a         rrca         rrca         rrca         push    af         and    1Fh         xor    l         ld    l, a         pop    af         push    af         rrca         and    0F0h         xor    l         ld    l, a         pop    af         and    0E0h         xor    h         ld    h, l         ld    l, a         inc    de         dec    bc         ld    a, b         or    c         jr    nz, crc1         ret
   und als Perl-Programm
 | Quellcode: |  #CRC-CCITT (CRC-16) x16 + x12 + x5 + 1  $POLY = 0x8408; # 16-12-5-1
  #this is the CCITT CRC 16 polynomial X^16+X^12+X^5+1 #This works out to be 0x1021, but the way the algorithm works #lets us use 0x8408 (the reverse of the bit pattern).  The high #bit is always assumed to be set, thus we only use 16 bits to #represent the 17 bit value. #1 0001 0000 0010 0001     16-12-5-1 #1000 0100 0000 1000 1     reverse -> 0x8408h
  #Startwert $crc16 = 0xFFFF;
  for ($i=0;$i<$len;$i++) {     my $bits = ord(substr($buf,$i,1));     for (0..7) {         if (($bits & 1) ^ ($crc16 & 1)) {             $crc16 >>= 1;             $crc16 ^= $POLY;         } else {             $crc16 >>= 1;         }         $bits >>= 1;     } } printf "CRC = %.4X\n", $crc16;
    -- VolkerP
  http://hc-ddr.hucki.net (Z9001, Z1013, LC-80, ...) |
